QNAP [ PGweb ] [ 0.12.0] Cross-platform client for PostgreSQL databases
QoolBox
Représentant QNAP
2 Janvier 2014
10 748
185
173
51
www.qnap.com
Oui
Source : http://sosedoff.github.io/pgweb/
Download :
Note :
listen on port 7891
About :
Most versions of PostgreSQL are supported, starting with official support for 9.1. Older versions could also be compatible but not guaranteed.
Pgweb can work with any local or remote PostgreSQL server (Heroku supported) as well as any server behind a firewall by using native SSH tunnelling with passwords or ssh keys. Quick-connect with server bookmarks.
Pgweb was designed to be very simple and clean UI to browse database tables or run and analyze SQL queries. Export query results or table rows to CSV/JSON/XML. Multiple schemas are supported. Records query history.
