QNAP [OpenHab ] [ 2.5.12 ] Build your smart home in no time
QoolBox
Représentant QNAP
2 Janvier 2014
10 743
185
173
51
www.qnap.com
Oui
7d388a86c95471f89b1bb911d96d7609a3e3a059.svg
Source : http://www.openhab.org/
Download : x64 , arm41 , arm64, arm-x31 , x86
https://www.qnapclub.eu/fr/qpkg/254
Notes :
Dependency = QJDK8
What is openHAB ?
openHAB is a software for integrating different home automation systems and technologies into one single solution that allows over-arching automation rules and that offers uniform user interfaces.
This means openHAB
is designed to be absolutely vendor-neutral as well as hardware/protocol-agnostic
can run on any device that is capable of running a JVM (Linux, Mac, Windows)
lets you integrate an abundance of different home automation technologies into one
has a powerful rule engine to fulfill all your automation needs
comes with different web-based UIs as well as native UIs for iOS and Android
is fully open source
is maintained by a passionate and growing community
is easily extensible to integrate with new systems and devices
provides APIs for being integrated in other systems
Projet intéressant, je ne le connaissais pas, je vais l'étudier :-)
Sent from my A0001 using Tapatalk
Bonjour. je viens d'installer Openhab 2.4.0 sur mon QNAS TS-439 avec un RFXCom en USB dessus. J'ai configuré un RFXCOM USB Transceiver sur /dev/ttyUSB0 mais celui ci apparaît tout le temps en déconnecté. Les commande de type sudo usermod -a -G dialout openhab ne fonctionne pas, j'ai une erreur de type sudo:command not found. Je precise que je suis un novice en linux. Pouvez vous m'aider?
legrand95 a dit:
tu devrais poster également sur le forum officiel en anglais dans le thread de OpenHAB
