Voici un extrait des échanges avec le support ASUSTOR.
avr 11 à 2h09 PM
À : esupport@asustor.comHello
Hello
I tryed the reset as explained but nothing better. See the attached photo.
I tryed 2 times.
Regards
avr 11 à 1h52 PM
You will find attaxhed the photo of the problem.
The Nas is correctly connected, all Led are Ok, the adsl rooter is ok...but there is no Ip adress.
This morning, everything was ok (without doing anything).
I start the reset but I really thibk that tha Network card has a problem...
Regards
avr 8 à 3h12 PM
À: esupport@asustor.com
Dear Amanda
No there is no IP address on top right corner of the home page.
I have already reset my router... without result...
To answer on the 2 points :
1. NAS and PC are connected on the same network. It used to work, untill Sunday 5th April...
The rooter management page dont "see" (=detect) the NAS. So, no IP adress.
2. that's the same : no IP address on rooter management page and NAS home page...
To resume and translate my first mail :
The NAS isn't detected neither on ISP rooter, ISP player, PC, tablet, smartphone.
No IP Adress, no access to Asustor portal (local or internet)
LEDs seem to be OK (blue one, green one, LAN)
--> Help !!!
Thank you,
De:"ASUSTOR Technical Support" <esupport@asustor.com>
Date:Jeu. 9 Avr. AM à 6:26
Objet:[#5962]: NAS AS304T non reconnu sur réseau local
Thanks for your reply.
Please help to check the following point.
1. Can you see the ADM icon on the TV? if yes, please try to use keyboard/mouse to login to ADM and go System Information > Network then take a picture of it to us.
2. Please try to reset your NAS to see whether it works.
http://support.asustor.com/index.php?/Knowledgebase/Article/View/11/0/how-do-i-reset-password-or-allow-the-connection-if-i-forget-the-password-of-admin--account-or-been-locked-by-adm-defender
3. Connect your NAS directly to a PC and provide the health record to us for investigation.
About how to connect your NAS directly to a PC:
http://support.asustor.com/index.php?/Default/Knowledgebase/Article/View/192/22/how-to-connect-my-nas-directly-to-a-pc
About how to generate the health record
http://support.asustor.com/index.php?/Default/Knowledgebase/Article/View/12/22/how-do-i-generate-the-health-record-on-my-nas
Please give it a try.
Thank you.
Please feel free to contact us, if you have any further questions or concern,
Regards,
Amanda Chen
De : ASUSTOR Technical Support <esupport@asustor.com>
Envoyé le : Mercredi 8 avril 2015 12h56
Objet : [#5962]: NAS AS304T non reconnu sur réseau local
Thanks for contacting with us.
Can you see the IP address on top right corner of the home page?
Please follow the point to see whether it works.
Before starting below process, please make sure NAS and PC are in the same local network area.
1. Log in your router management page to see if there is an IP address assigned to your NAS (by checking MAC address.) If yes, please check is the IP address in the management page same as your NAS IP address. If not, please reset your router.
2. If the IP address in the management page is same as NAS IP address and router has been reset, please reset your NAS.
Thank you.
Regards,
Amanda Chen
