lache seagate ironwolf 6Tb 256
rodrigue
9 Juillet 2018
182
10
23
42
ath
bonsoir,
j'ai mon hdd seagate 6To ironwolf qui laché des bruit tac tac tac!
peut etre laterne va bientot mort ?
le prix sav chez seagate va combien ça coute ?
voila
Salut, effectivement un bruit non-habituel peu etre un signe de la fatigue d'un disque dur ! Il faut s’inquiéter.
je vous conseil d'aller voir les détails des rapport SMART, et de les poster ici afin de ce faire une idée sur l'usure du disque.
rodrigue@rodrigue-MS-7B16:~$  sudo smartctl -s on -a /dev/sda
[sudo] Mot de passe de rodrigue :
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.7.19-050719-generic] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate IronWolf
Device Model:     ST6000VN0033-2EE110
Serial Number:    ZAD437DJ
LU WWN Device Id: 5 000c50 0b5963229
Firmware Version: SC60
User Capacity:    6.001.175.126.016 bytes [6,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Sep 13 09:10:19 2020 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 585) minutes.
Conveyance self-test routine
recommended polling time:        (   2) minutes.
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   082   064   044    Pre-fail  Always       -       150514900
  3 Spin_Up_Time            0x0003   086   085   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   099   099   020    Old_age   Always       -       1313
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   088   060   045    Pre-fail  Always       -       625768352
  9 Power_On_Hours          0x0032   096   096   000    Old_age   Always       -       3867
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       800
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   073   050   040    Old_age   Always       -       27 (Min/Max 21/27)
191 G-Sense_Error_Rate      0x0032   096   096   000    Old_age   Always       -       8053
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       243
193 Load_Cycle_Count        0x0032   094   094   000    Old_age   Always       -       12344
194 Temperature_Celsius     0x0022   027   050   000    Old_age   Always       -       27 (0 17 0 0 0)
195 Hardware_ECC_Recovered  0x001a   011   001   000    Old_age   Always       -       150514900
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       2698 (249 98 0)
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       29648574110
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       18333314554
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%      2374         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Effectivement le disque est en mauvaise état.
Raw_Read_Error_Rate, Seek_Error_Rate et Hardware_ECC_Recovered ont des valeurs elevés !
Le disque doit être remplacé ! S'il est encore sous garantie, faite une demande de RMA a Seagate.
EVOTk a dit:
ok merci
ma Garantie valide jusqu'au 18 juillet 2022
je retiré
mais comment envoyé sav seagate ?
Ici vous pouvez vérifier l'état de la garantie, en en bas de page faire une demande de prise en charge ( RMA )
https://www.seagate.com/fr/fr/support/warranty-and-replacements/
ma Garantie valide jusqu'au 18 juillet 2022 :mrgreen:
je vais une commande :)
