Source : https://github.com/Casvt/Kapowarr
Apache83 https://www.myqnap.org/product/kapowarr-apache83/
Apache84 https://www.myqnap.org/product/kapowarr-apache84/
Kapowarr is a software to build and manage a comic book library, fitting in the *arr suite of software.
Workings
Kapowarr allows you to build a digital library of comics. You can add volumes, map them to a folder and start managing! Download issues of the volume (or TPB's), rename them and move them. The whole process is automated and is all customisable in the settings.
Each day, each volume is checked to see if a new issue has come out and if so, it will immediately be downloaded and added to your library.
Features
Import your current library right into Kapowarr
Get loads of metadata about the volumes and issues in your library
Run a "Search Monitored" to download whole volumes with one click
Or use "Manual Search" to decide yourself what to download
Support for downloading directly from servers, via MediaFire and Mega
Downloaded files automatically get moved wherever you want and renamed in the format you desire
Zip files can be extracted and it's contents renamed after downloading or with a single click
The recognisable UI from the *arr suite of software
