QNAP [ iFtop ] [ 1.0.0 ] iftop does for network usage what top does for CPU usage [ CLI ]
QoolBox
Représentant QNAP
2 Janvier 2014
10 775
189
173
52
www.qnap.com
Oui
Source : http://www.ex-parrot.com/pdw/iftop/
Download :
x64 version https://www.qnapclub.eu/index.php?act=detail&qpkg_id=457
Note :
add iftop command (static built) to your NAS $PATH
Usage :
iftop: display bandwidth usage on an interface by host
Synopsis: iftop -h | [-npblNBP] [-i interface] [-f filter code]
[-F net/mask] [-G net6/mask6]
-h display this message
-n don't do hostname lookups
-N don't convert port numbers to services
-p run in promiscuous mode (show traffic between other
hosts on the same network segment)
-b don't display a bar graph of traffic
-B Display bandwidth in bytes
-i interface listen on named interface
-f filter code use filter code to select packets to count
(default: none, but only IP packets are counted)
-F net/mask show traffic flows in/out of IPv4 network
-G net6/mask6 show traffic flows in/out of IPv6 network
-l display and count link-local IPv6 traffic (default: off)
-P show ports as well as hosts
-m limit sets the upper limit for the bandwidth scale
-c config file specifies an alternative configuration file
