QNAP [Firmware Release] QTS 4.3.5.0756 build 20181110
QoolBox
Représentant QNAP
2 Janvier 2014
10 748
185
173
51
www.qnap.com
Oui
QTS 4.3.5.0756 build 20181110.
[Important Notes]
- To ensure system functionality, after updating QTS to 4.3.5, please also update Container Station to 1.9 in App Center before enabling QVR Pro.
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- Below are the kernel versions for NAS models that are supported by QTS 4.3.5:
Kernel 3.10.20: TS-128, TS-228
Kernel 3.2.26: TS-x31, TS-x31U
Kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
Kernel 4.2.8: all other models supported by QTS 4.3.5
- Due to the limitations of future kernel updates, QTS 4.3.5 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.5, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Lite.
[Fixed Issues]
- Fixed a command injection vulnerability in Media Library (CVE-2018-14746).
- Fixed a null pointer dereference vulnerability in Media Library (CVE-2018-14747).
- Fixed an improper authorization vulnerability (CVE-2018-14748).
- Fixed a stack-based buffer overflow vulnerability (CVE-2018-14749).
- QTS would sometimes still display error messages about unclean file systems even after users performed file system checks.
- Storage & Snapshots did not provide enough options or clear instructions for creating iSCSI LUNs.
- Network & Virtual Switch could not correctly display virtual adapters that had been created after users updated QTS to 4.3.5.0684.
- Users could not directly mount a remote NAS via FTP in File Station.
- QTS could not enter disk standby mode after users installed CloudLink.
- Checking file system for a volume during a folder migration would cause migration errors.
- QTS would display unexpected installation messages for SSD Profiling Tool when users restarted the NAS.
- When users searched for TV series in TheTVDB, Video Station could not display posters if the cast information was not available.
- Users could not expand the capacity of a volume to more than 16 TB even if the value of bytes per inode was set to 32 K.
- Users could not download data or search for torrents in Download Station after selecting a VPN connection as the gateway for Download Station in App Center.
- In Firefox, Music Station would still play the current track when users tried to skip to the next track.
- Users could not modify or delete the specified username when configuring the SMTP service account settings in Notification Center.
- In File Station, users could not mount a remote NAS that was joined to an Active Directory domain.
- Expanding thick volumes would cause longer NAS startup times.
- It would take longer than expected to open folders that contained .mp4 files in File Station.
- Users could not configure Service Binding settings after enabling VLAN for a port trunking group.
- Certain adapters would disappear from port trunking groups after users woke up the NAS from sleep mode.
- Using the Asmedia ASM1061 controller (firmware version 4.20) would cause disk errors.
- Users could only set the jumbo frame to 1500 for the QXG-10G1T network card.
- Users could not search for files in a shared folder mounted on macOS if the folder path contained spaces.
- Virtual switches would remove virtual adapters used by virtual machines after users woke up the NAS from sleep mode.
- Photo Station could not display photo tags that users added via SMB.
- myQNAPcloud would keep checking network connectivity after users disabled UPnP port forwarding.
- Resource Monitor could not display network usage for adapters where VLAN was enabled.
- Network & Virtual Switch could not detect the QM2-2P10G1T expansion card after users updated QTS to 4.3.5.0728.
- Users could not set the subnet mask of an adapter to 255.255.248.0 (/21).
- Inserting a USB external device to the NAS would change the SMB shared folder access permissions to the default settings.
- Network & Virtual Switch would stop responding after users set 255.255.255.255 as the netmask of a static route.
- Users could only set the jumbo frame to 1500 after installing a second network card.
- QTS could not detect the QM2-2S-220A expansion card and the M.2 SSDs installed on the card.
- Users could not open .eml files when using File Station in a new tab even if QmailAgent was installed.
- Users could not check the file system for a snapshot shared folder volume.
- Notification Center would send error messages when users downloaded files via a share link created by a non-administrator user.
- Users could not access the SQL server database after enabling Service Binding and creating a large number of virtual interfaces.
- Fan rotation speeds would increase unexpectedly after users woke up the NAS from sleep mode.
- The exFAT license could not function normally after users inserted an exFAT external drive and then restarted the NAS.
- Users could not play videos with VLC media player when using File Station in a new tab.
- Users could not play .m4a audio files in Music Station after pausing the files for a while.
- Static routes would sometimes disappear after users restarted the NAS.
- Users could not enable Domain Controller on the TS-x31 series even after configuring the default gateway.
- Users could not preview the files in Qsync folders when viewing a volume snapshot in Snapshot Manager.
- Network & Virtual Switch would display unrecognizable virtual adapters after users enabled OpenVPN and installed Container Station.
- After creating a virtual switch with a port trunking group using a static IP address, users could not access QTS when waking up the NAS from sleep mode.
- Unexpected error messages about DNS registration failure would appear when users joined the NAS to a domain and enabled WINS server.
https://download.qnap.com/Storage/HS-251/HS-251_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/IS-400/IS-400_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/Mustang-200/Mustang-200_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/QB-103/QB-103_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/SS-1279U/SS-1279U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/SS-1879U/SS-1879U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/SS-2479U/SS-2479U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-1079/TS-1079_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-1270U/TS-1270U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-1279U/TS-1279U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X41/TS-131P_231P_431P_X31+_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-1679U/TS-1679U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-470/TS-470_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-470U/TS-470U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-670/TS-670_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-870/TS-870_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-870U/TS-870U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-879/TS-879_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-879U/TS-879U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-KVM/TS-KVM_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X28A/TS-X28A_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X32/TS-X32_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X32U/TS-X32U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X35A/TS-X35A_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X51B/TS-X51B_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X53II/TS-X53A_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/SS-X53/TS-X53S_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X77/TS-X77_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X77U/TS-X77U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-XA28A/TS-XA28A_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-XA51/TS-XA51_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-XA73/TS-XA73_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-XA82/TS-XA82_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X63/TVS-X63_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X71/TVS-X71_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X71U/TVS-X71U_20181110-4.3.5.0756.zip
https://download.qnap.com/Storage/TS-X73/TVS-X73_20181110-4.3.5.0756.zip
Comme je le disais récemment, les updates deviennent une vrai galère (tout du moins sur mon NAS) et ce dernier ne fait pas exception à la règle...
- Redémarrage du NAS avant update
- Attente que tous les services soient up
- Mise à jour du firmware via l'admi QNAP
- 6 longs bip
- Le NAS ne répond plus
- Redémarrage forcé du NAS
- The first boot area on the flash is corrupted
- The first boot area on the flash has been recovered
- Mise à jour du firmware via Qfinder Pro
- Redémarrage auto du NAS
- The end, la NAS est reparti comme en 40
Bonne soirée
Merci pour ton retour QoolBox.
Mais bon, je n'ai plus de DOM, je l'ai viré et remplacé par autre chose quant il a rendu l'âme au firmware précédent :mrgreen:
Le DOM (Disk On Module) est une mémoire Flash qui contient l'image du firmware du NAS. A chaque démarrage, ton NAS boot sur cette image. QoolBox pourra certainement en dire plus que moi...
Le DOM de mon NAS :
Bonne journée
salut
ok je comprend, donc au final tu as soudé autre chose à la place ?
Je n'ai pas eu besoin de recourir à la soudure. Un bon vieux connecteur USB standard avec connecteur (4 broches ou 8 + 1 broches) et prise (s) standard USB-A et une clé USB et le tour est joué :mrgreen:
A noter que mon NAS est hors garanti. Donc, je déconseille de le faire sauf si le DOM est irrécupérable et le NAS hors garanti :!:
Une question, ces messages d'erreurs s'affichent dans le log ?
Mon NAS a seulement un peu plus d'un an et quelques mois après l'avoir acheté je ne peux plus faire les maj que depuis qfinder pro.. Depuis l'interface du nas ca rate à chaque fois. Avec qfinder ça marche à tous les coups. Par contre je n'ai pas ces messages dans le log, ça dit juste quelque chose comme "firmware update failed".
Ces messages sont susceptibles de s'afficher lors de la mise à jour d"un firmware raté ou comme le dit QoolBox, un DOM fatigué. Le système récupère le boot système de secours stocké sur la mémoire flash. En général, un réupdate du firmware règle le problème.
Par contre, je te rejoins sur tes propos, pour mon cas personnel, depuis une certain temps, depuis l'interface du NAS, les mises à jour échouent mais via Qfinder, ça fonctionne nickel.
Bonne journée
Ils ont mis de la mémoire flash premier prix ou quoi ? car ça tient bien dans le temps habituellement ce type de mémoire.
Dans mon cas, je n'ai aucun message au sujet de la flash, juste firmware uodate failed sans aucune autre info. Je trouve quand même bizarre que ça fonctionne avec qfinder et pas dans qts.
