QNAP [Firmware Release] QTS 4.3.5.0728 Build 20181013
Gravitys
27 Août 2015
355
QTS 4.3.5.0728 build 20181013
[Important Notes]
- To ensure system functionality, after updating QTS to 4.3.5, please also update Container Station to 1.9 in App Center before enabling QVR Pro.
- The RADVD service previously did not have an outgoing interface. Please reconfigure the RADVD service after upgrading.
- Due to security concerns, support for "Wi-Fi ad-hoc mode" has been removed.
- Below are the kernel versions for NAS models that are supported by QTS 4.3.5:
Kernel 3.10.20: TS-128, TS-228
Kernel 3.2.26: TS-x31, TS-x31U
Kernel 3.4.6: TS-x69, TS-x69U, TS-x69L
Kernel 4.2.8: all other models supported by QTS 4.3.5
- Due to the limitations of future kernel updates, QTS 4.3.5 is the final available QTS update for the following NAS models: TS-EC1679U-SAS-RP, TS-EC1679U-RP, TS-1679U-RP, TS-EC1279U-SAS-RP, TS-EC1279U-RP, TS-1279U-RP, TS-1079 Pro, TS-EC879U-RP, TS-879U-RP, TS-1270U-RP, TS-870U-RP, TS-470U-RP, TS-470U-SP, TS-879 Pro, TVS-870, TS-870 Pro, TS-870, TVS-670, TS-670 Pro, TS-670, TVS-470, TS-470 Pro, and TS-470.
- Due to the limitations of non-expandable memory capacity and 32-bit processor architecture, starting from QTS 4.3.5, the TS-128 and TS-228 no longer support Container Station and all the dependent applications, including Notes Station 3, Qcontactz, QcalAgent, AWS Greengrass, and QIoT Suite Lite.
[Fixed Issues]
- Expanding thick volumes would cause longer NAS startup times.
