QNAP [Firmware Release] QTS 4.3.3.0361 build 20171101
QoolBox
Représentant QNAP
2 Janvier 2014
10 793
191
173
52
www.qnap.com
Oui
[Important Notes]
- QTS 4.3.3 is the final available firmware update for the following models:
  TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Fixed Issues]
- Fixed multiple vulnerabilities in WPA2 to prevent the exposure of sensitive information via Wi-Fi networks (CVE-2017-13077, CVE-2017-13078, CVE-2017-13079, CVE-2017-13080, CVE-2017-13081, CVE-2017-13082, CVE-2017-13084, CVE-2017-13086, CVE-2017-13087, CVE-2017-13088).
- Fixed a vulnerability in the Linux kernel (CVE-2017-1000253).
- NAS-to-NAS backup jobs sometimes would fail due to unexpected errors on certain ARM models.
- HD Player would not be correctly displayed when users accessed HybridDesk Station on a browser via Remote Desktop.
- It would take a long time to delete multiple user accounts after granting them permissions to access a large number of files.
- Control Panel could not correctly display the DNS tree structure after users installed Python 2.7.12.
- Media Library would keep indexing files after users uploaded .flac files to the NAS.
- The USB LED on the NAS would keep blinking after users ejected a Transcend JetFlash USB drive.
- Users would encounter unexpected formatting errors when sending emails using IIS 6.0 as the SMTP server.
- Local user accounts could not share the same usernames with domain user accounts.
- Owners of shared folders could not access their folders when their access were denied in advanced folder permission settings.
- Syslog Viewer would display incorrect facility names.
- Users could not upload files larger than 2 GB to the TS-x31 series.
- Domain users could not access shared folders via FTP where they were granted access permissions.
- Special symbols in file names would be converted inconsistently when users uploaded files to the NAS via both AFP and SMB.
- System Connection Logs would display the connection type as HTTP when users accessed Download Station via HTTPS.
- Users could not select a volume to analyze in "Diagnostic Tool" > "File System Analyzer" on the TS-220.
https://download.qnap.com/Storage/TS-X77/TS-X77_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/HS-251/HS-251_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/IS-400/IS-400_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TAS-X68/TAS-X68_20171101-4.3.3.0361.zip
https://download.qnap.com/Storage/TS-X28/TS-X28_20171101-4.3.3.0361.zip
Merci !
Je suis toujours impressionné de voir le nombre de versions différentes ! Il doit y avoir une sacré organisation pour compiler et tester pour chaque modèle !
Par curiosité, je ne vois pas le ts-228 dans la liste ? j'ai ce modèle et j'ai bien reçu la nouvelle version :)
