QNAP [Firmware Release] QTS 4.3.3.0351 build 20171023
QoolBox
Représentant QNAP
2 Janvier 2014
10 748
185
173
51
www.qnap.com
Oui
[Important Notes]
[Fixed Issues]
- Fixed a TCP sequence number prediction vulnerability that could be exploited to cause a denial of service.
- Fixed a command injection vulnerability in Media Library that could allow for remote command execution (CVE-2017-13067).
- Fixed a command injection vulnerability in myQNAPcloud.
- Fixed multiple stack overflow vulnerabilities that could allow for remote command execution.
- Fixed an "Orpheus' Lyre" vulnerability in Samba that could be exploited to bypass authentication mechanisms (CVE-2017-11103).
- Updated the version of OpenSSH to 7.5 to fix an information disclosure vulnerability.
- Updated the version of SAMBA to 4.6.7 to fix multiple vulnerabilities regarding SMB signing (CVE-2017-12150), encryption across DFS redirections (CVE-2017-12151), and server memory information leakage (CVE-2017-12163).
- Fixed an information exposure vulnerability to prevent unauthorized access to sensitive information (CVE-2017-7630).
- Changed the access permissions for the files "/etc/passwd", "/etc/group", and "/etc/shadow" to enhance data security.
- It would take a long time for the Control Panel to display all domain users if the domain had a large number of users and groups.
- Resource Monitor can correctly display CPU and memory usage when users enable version control for Qsync and then synchronize a large number of files.
- Users' Freebox routers would output data in an unexpected XML format.
- Users could not enable Web Server after enabling secure connection (HTTPS) in Control Panel.
- Users could not access HybridDesk Station via Remote Desktop when enabling secure connection (HTTPS).
- The NAS could not enter the disk standby mode when using a USB Wi-Fi dongle to connect to a network via an access point.
- The kswapd (kernel swap daemon) process would cause high CPU usage on the TS-870 Pro.
- After users updated the QTS version to 4.3.3.0229 and then connected external devices to the TS-219, the NAS could not recognize a connected power supply unit.
- Users could not access their Microsoft OneDrive for Business folders in File Station after installing Connect to Cloud Drive.
- Users could not back up the LDAP database to a specified location after joining the NAS to an LDAP directory.
https://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/HS-251/HS-251_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/IS-400/IS-400_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20171023-4.3.3.0351.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20171023-4.3.3.0351.zip
pour info
4.3.4 Beta for ARM models is released today.
The live update (for Beta program enabled only) will open on Monday.
This 4.3.4 Beta release is only for ARM models:
TS-x31, TS-x31+, TS-x31P/P2, TS-x31X/XU, TS-x35
If customer wants to downgrade 4.3.4 Beta to 4.3.3, they MUST downgrade to 4.3.3 20171023 build which was also released today. Older versions are not compatible with downgrade.
Hybrid Backup Sync app must be updated in the App Center after installing 4.3.4 Beta.
The previous versions are not compatible.
bizarre, cette version n'est toujours pas dispo via l'install auto.. il y a t'il un souci ?
