QNAP [Firmware release] QTS 4.3.3.0238 build 20170703
QoolBox
Représentant QNAP
2 Janvier 2014
10 797
191
173
52
www.qnap.com
Oui
[Important Notes]
- QTS 4.3.x is the final available firmware update for the following models:
  TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Fixes]
- External drives formatted in NTFS or HFS+ are not erroneously shown as uninitiated in Storage Manager on the TAS-x68 and TS-x28 series.
- Copied files do not become corrupted when users connect to the NAS via SMB and then copy and paste files within the same shared folder on an encrypted volume.
- Photo Station and Video Station can successfully generate thumbnails for photos and videos on the ARM models.
- Backup Station can correctly display destination folders in a tree view when users create a local-to-remote CIFS/SMB RTRR job.
- Users can perform NAS-to-NAS backup jobs when an external drive formatted in NTFS is connected to the NAS and when the option "Replicate ACL and extended attributes" is enabled in Backup Station.
- Resource Monitor can correctly display the line chart for the CPU usage when users open the management screen for a storage pool on Storage Manager.
- Users can disable schedule options when creating a snapshot schedule on Storage Manager.
- Guest users can be successfully directed to the root directories where they are granted access permissions when connecting to the NAS via FTP.
- The user interface in "Control Panel" > "Applications" > "Web Server" > "Virtual Host" now functions as expected.
- Fixed a denial-of-service vulnerability regarding the ntpd (Network Time Protocol daemon).
- Users can create local-to-remote RTRR backup jobs for shared folders when connecting from a Mac via SMB.
- The volume labels of external drives can be changed to user-specified names when users format the drives to NTFS.
- Users can log on to QTS as "admin" without being affected by unexpected errors in certain configuration files.
[Other Changes]
- In this update, RAID scrubbing is automatically scheduled to run on the first day of every month at 02:15. RAID scrubbing checks the data integrity of all RAID 5 and RAID 6 groups on the NAS. Running this check regularly is recommended. Storage performance might be degraded while RAID scrubbing is running. You can modify the schedule at "Storage Manager" > "Global Settings" > "RAID Scrubbing".
- Changed the warning and error log entries created when QTS finds a RAID bad block or bad stripe.
- After updating the NAS managed by Q'center from 4.2.x to 4.3.x, the administrator of Q'center must input the password of each NAS to continue monitoring.
- Virtualization Station
  Due to advancements in the backup features, virtual machines created in older versions (1.x/2.x) of Virtualization Station can no longer be backed up and restored in 3.0. (A workaround is to clone an older Virtual Machine; the cloned VM can be backed up/restored, but all original snapshots will be removed)
https://download.qnap.com/Storage/HS-210TurboNAS/HS-210_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/HS-251/HS-251_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/IS-400/IS-400_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X31P2/TS-X31P2_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X31X/TS-X31X_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X53BU/TS-X53BU_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X73U/TS-X73U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20170703-4.3.3.0238.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20170703-4.3.3.0238.zip
installé par la mise à jour standard depuis quelques jours: so far, so good :)
