QNAP [firmware release] QTS 4.3.3.0180 build 20170509
QoolBox
Représentant QNAP
2 Janvier 2014
10 775
189
173
52
www.qnap.com
Oui
[Important Notes]
- QTS 4.3.x is the final available firmware update for the following models:
  TS-112P, TS-212P, TS-212-E, HS-210, TS-112, TS-212, TS-121, TS-221, TS-421 TS-120, TS-220, TS-420, TS-420U, TS-421U TS-412, TS-412U, TS-419U, TS-419U+, TS-419U II, TS-119P II, TS-219P II, TS-419P II, TS-119P+, TS-219P+, TS-419P+, TS-119P, TS-219P, TS-419P, TS-119, TS-219, TS-419
[Enhancements]
Added support for the USB 3.1 PCIe card USB-U31A2P01 on the following NAS models: TVS-463/663/863/863+, TS-563, TS-463U/863U/1263U, TVS-471/671/871, TVS-471U/671U/871U, TVS-682/882/1282, TVS-682T/882/1282T, and TES-1885U/3085U.
[Fixes]
- Users can successfully copy files from Promise DAS devices to the NAS using AFP via Thunderbolt.
- The "Snapshot management" option is correctly displayed on the "More" menu of the volumes on the left pane on File Station.
- Users can successfully edit WebDAV connections and save the changes on File Station.
- Apache daemon can successfully start when the Web Server service is enabled.
- Users need to specify the correct password to continue when creating a Rsync backup job from a QNAP NAS to a Synology NAS.
- Users can upload files that have filenames beginning with "._" to shared folders via SMB.
[Known Issues]
The NAS runs out of memory when using thin volumes or LUNs and space reclamation on QTS 4.3.
Note: If your NAS has been online for more than one month, QNAP recommends closely monitoring the memory usage and manually restarting the NAS when necessary. QNAP has identified the root cause and will include a patch for this issue in the next release."
[Other Changes]
- After updating the NAS managed by Q'center from 4.2.x to 4.3.x, the administrator of Q'center must input the password of each NAS to continue monitoring.
- TwonkyMedia is no longer supported. Use the DLNA Media Server built into QTS as your DLNA server.
- Download Station
  Users can now be notified when downloads complete (instead of when download tasks complete).
- Virtualization Station
  Due to advancements in the backup features, virtual machines created in older versions (1.x/2.x) of Virtualization Station can no longer be backed up and restored in 3.0. (A workaround is to clone an older Virtual Machine; the cloned VM can be backed up/restored, but all original snapshots will be removed)
https://download.qnap.com/Storage/HS-251/HS-210_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/HS-251/HS-251_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/IS-400/IS-400_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/SS-EC1279U-SAS-RP/SS-1279U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/SS-EC1879U-SAS-RP/SS-1879U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/SS-EC2479U-SAS-RP/SS-2479U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-1079ProTurboNAS/TS-1079_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-112TurboNAS/TS-112_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-119TurboNAS/TS-119_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-120TurboNAS/TS-120_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-121TurboNAS/TS-121_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-1269U-RP/TS-1269U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-1270U-RP/TS-1270U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-1279U-RP/TS-1279U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-131P_231P_431P_X31+/TS-131P_231P_431P_X31+_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-1679U-RP/TS-1679U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-212TurboNAS/TS-212_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-219TurboNAS/TS-219_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-220TurboNAS/TS-220_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-221TurboNAS/TS-221_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-269ProTurboNAS/TS-269_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-412TurboNAS/TS-412_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-412UTurboNAS/TS-412U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-419PTurboNAS/TS-419P_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-419UTurboNAS/TS-419U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-420TurboNAS/TS-420_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-420UTurboNAS/TS-420U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-421TurboNAS/TS-421_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-421UTurboNAS/TS-421U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-469ProTurboNAS/TS-469_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-469U-RP/TS-469U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-470ProTurboNAS/TS-470_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-470U-RP/TS-470U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-531P/TS-531P_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-563/TS-563_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-569ProTurboNAS/TS-569_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-669ProTurboNAS/TS-669_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-670ProTurboNAS/TS-670_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-869ProTurboNAS/TS-869_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-869U-RP/TS-869U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-870ProTurboNAS/TS-870_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-870U-RP/TS-870U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-879ProTurboNAS/TS-879_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-879U-RPTurboNAS/TS-879U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X31/TS-X31_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X31U/TS-X31U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-531X_831X/TS-X31X_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X31XU/TS-X31XU_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X35/TS-X35_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X51/TS-X51_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X51A/TS-X51A_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X51U/TS-X51U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X53/TS-X53_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X53A/TS-X53A_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X53B/TS-X53B_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X53S/TS-X53S_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X53U/TS-X53U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X63U/TS-X63U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X80/TS-X80_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X80U/TS-X80U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X82/TS-X82_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X82S/TS-X82S_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X82U/TS-X82U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X85/TS-X85_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X85U/TS-X85U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TS-X89U/TS-X89U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TVS-X63/TVS-X63_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TVS-X71/TVS-X71_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TVS-X71U/TVS-X71U_20170509-4.3.3.0180.zip
https://download.qnap.com/Storage/TVS-X73/TVS-X73_20170509-4.3.3.0180.zip
Merci, très proche de la précédente update dis donc ! En tout cas en c'est fait, Qoolbox toujours sur la brèche merci ;)
Nouvelle qui arrive je pense :o J'ai eu la x51 ce matin et la le lien est mort.
Des nouvelles du retrait de la 180 ? Je suis dessus la et je ne sais pas si elle a été retirée pour un soucis majeur, c'est plutôt inquiétant :/
