Dans un premier temps le 4.2.1 officiel sort pour les TS-x53A et TDS-16489U
dans le live update le 19 janvier
QTS 4.2.1 Build 1226
[Applicable Models]
- TS-x53A series and TDS-16489U
[New Feature]
QTS
- Added the Virtual Switch function to Network & Virtual Switch.
- Added the “Overview” page for Internet topology settings.
- Both the Virtual Switch application and QTS firmware do not support downgrading.
- The system cannot slow down network speeds when using a 10GbE or 40GbE ethernet card or port trunking.
Notification
- Added Oauth 2.0 support for SMTP Gmail accounts (“Desktop” > “Options” > “E-mail Account”).
- Added Oauth 2.0 support for SMTP Gmail accounts (“Control Panel” > “Notification” > “E-mail”).
App Center
- Improved the user interface.
- Apps from third-party sources can now be imported in the App Center (“Settings” > “App Repository”).
Photo Station
- The aspect ratio of photo thumbnails can now be changed. (“Manage” > “Settings” > “Miscellaneous”).
- Added third-party domain name support for sharing links.
VPN Server
- The NAS can now be set as both a PPTP and OpenVPN VPN server and client.
VPN Client
- Support multiple PPTP and OpenVPN VPN connection.
App
Linux Station
- Added the ability to select volumes for app installation in the App Center.
- Added the ability to migrate Linux Station to another volume.
- At least 4GB RAM is required to install Standard Linux desktop system. (please note that Linux Station and HD Station cannot be run at the same time).
- For TS-x53A series only
Proxy Server
- Added Proxy Server for cache and connection controls for Internet services in the App Center.
[Enhancement]
QTS-Misc
- Upgraded UnRAR to v5.3.3, Zip to v3.0, and Unzip to v6.0.
- Upgraded Netatalk to v3.0.8.
- Added GMT-3:00 Greenland Standard Time and Nuuk (Godthab) time zones (in "Control Panel" > "General Settings" > "Time").
File Station
- In File Station, remote connection default settings have changed from administrator only to administration group only.
- Only administrators can permanently delete files from File Station. Files deleted by other users will be moved to the Trash.
OpenSSL
- OpenSSL has been updated to 1.0.0t/ 1.0.1q.
[Change]
QTS-Misc
- Removed the DLNA Media Server option in Bonjour (“Control Panel” > “Service Discovery” > “Bonjour”).
[Note]
Media Streaming Add-on
- When updating to QTS 4.2.1, the Media Streaming Add-on must be updated to version 421.0.1.0 (or newer) to work properly.
[Bug Fixes]
This release has corrected the following issues:
QTS
- Fixed an issue where the NAS would not accept a domain group's name if it contains special characters.
- Fixed an issue where email notifications would be disabled when using 2-step verification if there is no username & password set in the SMTP server.
- Fixed an issue where testing a RTRR job would fail when creating a job to backup files from local to remote via CIFS.
- Fixed an issue where the profile folder would have two IDs with the access right of 3000001 after the domain users setup profiles.
- Fixed an issue where after detaching a JBOD, its image in Storage Manager will remain in chassis view.
- Fixed an issue where after installing CloudLink and rebooting the NAS, the System Event Logs will display a "..file system is not clean.." message.
- Fixed an issue where the progress would be stuck at "0" when relaunching Storage Manager and entering "Storage Space" page when using Internet Explorer 11.
- Fixed an issue where after enabling advanced folder permissions in the Control Panel, File Station would show an error message in the right-panel Permission tab.
- Fixed an issue where File Station would show an error message when sharing files with more than one person and sending an email link via the NAS.
- Fixed an issue where the Expand Capacity button will be enabled before changing any drive in Storage Manager.
- Fixed an issue where an increasing amount of system RAM will be displayed while copying a large number of small files to the NAS.
- Fixed an issue where the unallocated size will change after taking snapshots, copying some files, then rebooting the NAS.
- Fixed an issue where the content of encrypted folders are not included in snapshots.
- Fixed an issue where the system will fail to create a snapshot replica job to a remote NAS when there is a special character ')' in the password.
- Fixed an issue where there is nothing shown in Background Tasks after Snapshot Replica is executed.
- Fixed an issue where the Media Library would occasionally show incomplete file information when changing the iTunes media folder to the NAS multimedia folder.
- Fixed an issue where the WebDAV connection would fail after the HTTPS port is changed to 443.
- Fixed an issue where the content page of songs would be cleared when uploading specific MP3 files.
- Fixed an issue where the AFP connection would be interrupted when connecting through an encrypted folder.
- Fixed an issue where files would be incompletely moved when repeatedly moving files between a shared folder and an external folder in File Station.
Virtualization Station 2.1
- The button "Processing immediately after Apply" does not work after creating a restore job with instant bootup.
- The error message when accessing Virtualization Station from an iPad 4.
- Upgrading Virtualization Station will not modify the SSL certification.
- Allows logging into Virtualization Station when "Force secure connection (HTTPs) only" is enabled in General Settings.
- There is no VM backup timestamp for restoring remote backup jobs by clicking the "Restore" button.
