Synology Firmware DSM 7.0-41890 disponible
JujuY
Maître Jedi
6 Mars 2018
721
58
58
Depuis le 19 juillet la version DSM 7.0-41890 est disponible et proposée en téléchargement
(2021-07-19)
Important notes
DSM 7.0-41890 is updated on July 19 to fix issues with SAN Manager 1.0.1-0197, Active Insight 1.0.2-1007, and SMB Service 4.10.18-0223. Users who have already installed this version of DSM are recommended to update the packages in Package Center.
Before Update
The update is expected to be available for all regions within the next few weeks, although the time of release in each region may vary slightly. If you want to update to the latest version now, please go to Synology Download Center and manually update your DSM.
After the installation of DSM 7.0, you will not be able to downgrade to a previous DSM version.
Before updating, your Synology NAS should be running DSM 6.2 or above versions.
Reserve extra time to complete DSM 7.0 update. The DSM update takes 10 to 20 minutes, while package update may take more than an hour. The actual time depends on the computing power of your model, the number of media indexing files, and the number of packages installed.
If you're performing a clean installation, make sure to complete the installation with find.synology.com or Synology Assistant 7.0-50029 or above.
To avoid possible compatibility issues, users who installed Active Insight, Synology Photos, and Secure SignIn mobile applications during DSM 7.0 Preview/Beta programs should update the applications to the latest version after the DSM update.
DSM 7.0 consumes more system resources, including memory. If your model has less than 1 GB of memory, updating to DSM 7.0 may affect system performance.
This version of DSM is compatible with the models below. DSM 7.0 for FS, SA, XS/XS+, and DVA series is currently under development and will be available in the next quarter.
21-series: RS2821RP+, RS2421RP+, RS2421+, RS1221RP+, RS1221+, DS1821+, DS1621+
20-series: RS820RP+, RS820+, DS1520+, DS920+, DS720+, DS620slim, DS420+, DS420j, DS220+, DS220j, DS120j
19-series: RS1219+, RS819, DS2419+II, DS2419+, DS1819+, DS1019+, DS419slim, DS119j
18-series: RS2818RP+, RS2418RP+, RS2418+, RS818RP+, RS818+, DS1618+, DS918+, DS718+, DS418, DS418play, DS418j, DS218+, DS218, DS218play, DS218j, DS118
17-series: RS217, DS1817+, DS1817, DS1517+, DS1517
16-series: RS2416RP+, RS2416+, RS816, DS916+, DS716+II, DS716+, DS416, DS416play, DS416slim, DS416j, DS216+II, DS216+, DS216, DS216play, DS216j, DS216se, DS116
15-series: RS815RP+, RS815+, RS815, DS2415+, DS1815+, DS1515+, DS1515, DS715, DS415+, DS415play, DS215+, DS215j, DS115, DS115j
14-series: RS2414RP+, RS2414+, RS814RP+, RS814+, RS814, RS214, DS414, DS414slim, DS414j, DS214+, DS214, DS214play, DS214se, DS114
13-series: DS2413+, DS1813+, DS1513+, DS713+, DS213j
For the models below, you can only download the upgrade patch from Synology Download Center because you won't receive notifications for this update on your DSM.
15-Series: RS815RP+, RS815+, RS815, DS2415+, DS1815+, DS1515+, DS1515, DS715, DS415+, DS415play, DS215+, DS215j, DS115, DS115j
14-Series: RS2414RP+, RS2414+, RS814RP+, RS814+, RS814, RS214, DS414, DS414slim, DS414j, DS214+, DS214, DS214play, DS214se, DS114
13-Series: DS2413+, DS1813+, DS1513+, DS713+, DS213j
DSM
USB devices (Wi-Fi dongle, Bluetooth dongle, 3G/4G dongle, USB DAC/speaker, and DTV dongle) are no longer supported. If your Synology NAS is currently connected via a wireless dongle, it will be disconnected after the update.
DSM 7.0 will end support for ext3. We strongly suggest backing up the data stored on your ext3 volumes and transferring the data to volumes with supported file systems before the update.
DSM 7.0 by default disables NTLMv1 and enables NTMLv2 only, so SMB clients (e.g., Windows XP devices, media players, network printers, smart TVs, and IP cameras) won’t be able to access your Synology NAS. To restore the connection after the update, go to Control Panel > File Services > SMB > Advanced Settings > Others and enable NTLMv1 authentication.
NFSv4.1 and related advanced functions (multipathing) are no longer supported on Synology NAS models with the following package architectures: Alpine, Alpine4k, armada38x, Avoton, Braswell, Bromolow, Cedarview, Grantley, Monaco. If you had previously enabled NFSv4 and NFSv4.1, the maximum NFS protocol is set to NFSv4 by default after the update. For more information about the package architecture of your model, please refer to this article.
Creating SSD caches on block-level LUNs is no longer supported. Existing SSD caches for block LUNs will function normally after the update.
NT4 domains are no longer supported. Current NT4 domains will be unavailable after the update.
The URLs used by DSM when updating or running services have been modified. Please read this article and make sure that your firewall rules are configured appropriately.
iSCSI Manager will become SAN Manager on DSM 7.0. Please refer to package release notes for more details.
When you reconnect to iSCSI targets from your VMware ESXi hosts after the DSM update, the datastores on the LUNs that are mapped to the targets may not be mounted properly. This only happens to LUNs created before the update. The resolution can be found in VMware Knowledge Base.
To provide comprehensive TLS support and ensure compatibility, the TLS/SSL profile level in Modern compatibility will automatically change to Intermediate Compatibility after the update.
EZ-Internet is merged with Router Configuration in Control Panel. To set up port forwarding, go to Control Panel > External Access > Router Configuration.
Python3 is merged into DSM as a built-in service. The original Python3 package will be unavailable in Package Center and you can remove it manually.
The following DDNS providers are removed from the service provider list at Control Panel > External Access > DDNS:
CloudNS, DNO-O-Matic, DNSEXIT, Dynamic DO!.jp, Joker.com, RU-CENTER, TwoDNS.de, Variomedia, Zoneedit.com
The updated QuickConnect connection is secured with an SSL certificate, and your QuickConnect domain will be passed to Let's Encrypt for certificate application purposes. Please refer to the Privacy Statement for more details.
Security Advisor by default enables Login Analysis and certain custom account detection check items after the update.
Video conversion to FLV and MPEG-4 Part 2 formats on the following models is no longer supported.
20-series: DS120j
19-series: DS119j
16-series: DS216se
15-series: DS215j, DS115, DS115j
14-series: RS814, RS214, DS414, DS414slim, DS414j, DS214+, DS214, DS214se, DS114
13-series: DS213j
Active Insight & Hybrid Share Service are build-in services available with DSM 7.0 Official, these two services will be automatically installed as Beta version after the update.
Packages
Synology Moments and Photo Station will be upgraded to and merged as Synology Photos. If you would like to use Synology Photos on your mobile devices, please install the iOS/Android app. See this page for more details.
Cloud Station Server and Cloud Station ShareSync will be upgraded to and merged with Synology Drive Server. If you are using any Cloud Station Suite applications (Cloud Station Server, Cloud Station Drive, Cloud Station Backup, Cloud Station ShareSync, or DS cloud), you must switch to their counterparts in the Synology Drive Suite to ensure compatibility. See this page for more details.
MariaDB 5 is incompatible with DSM 7.0. To update to DSM 7.0, please install MariaDB 10, migrate the database, and uninstall MariaDB 5 in Package Center first.
Migration Assistant is currently in beta on DSM 7.0. More information can be found on the Beta Program page, including compatibility details and release notes.
If you cannot find certain Synology approved third-party packages in Package Center, check this article for the latest status of the packages. For other third-party packages, please contact their developers for more information.
The following packages are no longer supported:
Cloud Station Server (replaced by Synology Drive Server), Cloud Station ShareSync (replaced by Synology Drive Server), Discourse, DokuWiki, Drupal, Drupal8, DVBLink, GitLab, GLPI, Hasplm, Java7, Java8, LimeSurvey, Logitech® Media Server, LXQt, Magento, Magento2, MantisBT, Moments (replaced by Synology Photos), Mono, Moodle, Node.js 0.10, Node.js 0.12, Node.js v4, Node.js v6, Node.js v8, Odoo 8, OpenERP 6.1, OpenERP 7.0, OrangeHRM, Orthanc, osCommerce, osTicket, PHP PEAR, Photo Station (replaced by Synology Photos), phpBB, Piwik, Podcast Generator, PrestaShop, PrestaShop1.7, PythonModule, Redmine, Ruby, Spree, SugarCRM, SVN, Synology File Manager, Tomcat6, Tomcat7, TVMosaic, Webalizer
After you update to Web Station 3.0.0-0308, a web_packages shared folder will be created by default to store files from installed third-party packages (e.g., phpMyAdmin).
