Synology Firmware DSM 6.2.4
Administreur
2 307
293
Surprise pendant la nuit :)
DSM 6.2.4
Version: 6.2.4-25554
(2021-02-23)
Important Note
Your Synology NAS may not notify you of this DSM update because of the following reasons. If you want to update your DSM to this version now, please click here to manually update it.
The update is not available in your region yet. The update is expected to be available for all regions within the next few days, although the time of release in each region may vary slightly.
This update will restart your Synology NAS.
Compatibility & Installation
Enhanced the password policy. Passwords must exclude usernames and descriptions, include both upper-case and lower-case letters as well as numerical digits. The minimum password length is 8 characters.
Fixed a compatibility issue between the Geminilake platform and virtual machines running Windows 10.
On a newly installed version of DSM, file rename and deletion log events for SMB will be enabled by default.
What's New
Users can now set 10 email addresses to receive system notifications.
Enhanced domain database synchronization performance by syncing only altered data.
Supports bad block detection on Synology SSDs.
Supports the updating of Synology HDD and SSD firmware directly via DSM.
Improved fan speed control based on the Synology network interface card temperature for 19-series and newer models.
Fixed Issues
Fixed an issue where the "Enable Web Assistant" option didn't work on NVR216 and NVR1218.
Fixed an issue where the date and time formats for scheduled tasks were inconsistent in the widget and system settings.
Fixed an issue where scheduled tasks may fail to be executed or modified.
Fixed an issue where tasks scheduled at a high frequency generated a lot of logs and occupied system partitions.
Fixed an issue where the custom welcome text may differ on the preview and actual login page due to character limits.
Fixed an issue where data could still be written to LUNs after the volume runs out of space.
Fixed an issue where if Wi-Fi dongles are installed, some available network interfaces weren't listed when users edit iSCSI targets.
Fixed an issue where iSCSI services may be unstable when the host is too busy or when users disable iSCSI targets and ending sessions simultaneously.
Fixed an issue where initiators couldn't connect to the iSCSI target after ethernet interfaces reconnect in a high-availability cluster.
Fixed an issue where packages may not operate properly when drives migrated from another Synology NAS cause volume ID conflicts.
Fixed an issue where users may not be able to find their Synology NAS in My Network Places on Windows when WS-Discovery isn't operating properly.
Fixed an issue where Log Center didn't record recycle bin enabling/disabling events.
Fixed a security vulnerability regarding Sudo. (Synology-SA-21:02)
Fixed multiple security vulnerabilities. (Synology-SA-21:03)
Limitations
In response to the enhancement of domain database synchronization efficiency, the domain user/group list will be updated once an hour when it is created with Synology Directory Server.
https://www.synology.com/fr-fr/releaseNote/DSM?model=DS920%2B
Synology viens de publier la note de version de DSM 6.2.4-25556 :
This update includes fixes to the below issues mentioned in 6.2.4-25554.
Fixed an issue where external hard drives couldn't wake from hibernation on certain platforms (Grantley, Broadwell, Broadwellnk, Broadwellntbap, Purley).
Fixed an issue where users could not sign in to Synology mobile apps after they had cleared the remembered device list in DSM 6.2.4.
Google Translate :
Cette mise à jour inclut des correctifs aux problèmes ci-dessous mentionnés dans 6.2.4-25554.
Correction d'un problème où les disques durs externes ne pouvaient pas sortir de l'hibernation sur certaines plates-formes (Grantley, Broadwell, Broadwellnk, Broadwellntbap, Purley).
Correction d'un problème où les utilisateurs ne pouvaient pas se connecter aux applications mobiles Synology après avoir effacé la liste des appareils mémorisés dans DSM 6.2.4.
Version: 6.2.4-25556
(2021-03-08)
Important Note
Integrates the beep control options for degraded/crashed volumes and abnormal SSD caches.
The new LED indicator behavior makes the system status easier to distinguish on 15-series and newer models. (Learn more)
DNS Server must be updated to version 2.2.3-5028 or above to be compatible with this update.
LDAP Server must be updated to version 2.4.49-2515 or above to be compatible with this update.
What's New
Fixed Issues
Limitations
Attention à certaines séries qui auraient des soucis avec cette update
https://community.synology.com/enu/forum/1/post/142519 :shock:
un peu plus d'infos chez syno
ils reconnaissent que ces volumes BTRFS auraient été importés de nas compatilbles vers des nas non compatibles lors de migrations de disques...
ce qui n'aurait normalement pas u être possible
ça sent le "use case "non pensé
Cette liste de NAS (DS420j, DS220j, DS418j, DS218play, DS118), gérant uniquement le système de fichiers EXT4, et posant officiellement un problème avec DSM6.2.4 si le système de fichier réel est le BTRFS, me semble réduite par rapport à des modèles qui sont très proches (même processeur : Realtek RTD1293 ou RTD1296). Je pense au DS218 et au DS418.
Il y a bien sûr d'autres gammes, dotées de processeurs différents (Intel, Marvell, etc), qui gèrent uniquement le système de fichiers EXT4, mais qui ne semblent pas affectées.
