Source : https://fhem.de
Download :
X64 Version : https://www.qnapclub.eu/fr/qpkg/459
Dependency :
QPerl 5.26.0 +
Note :
Listen on port 8083 by default
other port use 7072 , 8084, 8085
Config file : /opt/fhem/fhem.cfg
About :
FHEM (TM) is a GPL'd perl server for house automation. It is used to automate some common tasks in the household like switching lamps / shutters / heating / etc. and to log events like temperature / humidity / power consumption.
The program runs as a server, you can control it via web or smartphone frontends, telnet or TCP/IP directly.
In order to use FHEM you'll need a 24/7 server (NAS, RPi, PC, MacMini, etc) with a perl interpreter and some attached hardware like the CUL-, EnOcean-, Z-Wave-USB-Stick, etc. to access the actors and sensors. See the "Supported hardware" section below.
It is pronounced without the h, like in feminine.
Features
support for a lot of protocols used in house automation, audio/video devices, weather services, online calendars and more.
autocreating devices/logs when receiving data from a new device: start FHEM and watch how the plots of your sensors are appearing automatically.
logging events to files or a database, with regexp filters
notifying external programs or scripts when receiving certain events
timed commands (e.g. switching a lamp on from sunset till midnight)
lot of interfaces: simple text, JSON, XML, each of them over plain TCP/IP, SSL or HTTP.
modular architecture with currently over 430 modules, easy to add your special device
lot of frontends, choose your favorite
Supported protocols (small excerpt)
eQ3 spezifisch: HomeMatic, MAX!, FS20, EM1000, FHT80b, HMS, S300, ESA2000
KNX, ZWave, EnOcean, Philipps HUE, FRITZ!Dect, Intertechno, HomeEasy, X10
1Wire, Firmata, webio, panStamp, LIRC, JeeLink, RFXCOM/RFXTRX, Wireless M-Bus
Davis VantagePro2, Oregon Scientific, Allnet
TVs from LG, Panasonic, Philips, Samsung, Sony
Devices from Bose, Sonos, Squeezebox
Amplifier from Denon, Onkyo, Pioneer, YAMAHA
iTunes/AppleTV, Enigma2, XBMC/Kodi, MediaPortal, Plex
Alexa, HomeKit, HomeBridge
