Erreur OMV sur Raspberry PI
Moustic
3 Juillet 2019
Bonjour a tous
Je suis en train de créer mon NAS avec un raspberry PI et OMV.
J'ai fait une MAJ et au moment de modifier mon parefeu, il refuse mes modifs, impossible de les valider...
Merci de votre aide !
Voici le message :
La configuration a été modifiée. Vous devez appliquer les changements pour qu'ils prennent effet.
IPv4
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; /etc/network/if-pre-up.d/openmediavault-iptables 2>&1' with exit code '3': iptables v1.6.0: can't initialize iptables table `filter': Table does not exist (do you need to insmod?) Perhaps iptables or your kernel needs to be upgraded.
Erreur #0:
OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; /etc/network/if-pre-up.d/openmediavault-iptables 2>&1' with exit code '3': iptables v1.6.0: can't initialize iptables table `filter': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded. in /usr/share/php/openmediavault/system/process.inc:182
Stack trace:
#0 /usr/share/openmediavault/engined/module/iptables.inc(46): OMV\System\Process->execute()
#1 /usr/share/openmediavault/engined/rpc/config.inc(194): OMVModuleIptables->startService()
#2 [internal function]: OMVRpcServiceConfig->applyChanges(Array, Array)
#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#4 /usr/share/php/openmediavault/rpc/serviceabstract.inc(149): OMV\Rpc\ServiceAbstract->callMethod('applyChanges', Array, Array)
#5 /usr/share/php/openmediavault/rpc/serviceabstract.inc(565): OMV\Rpc\ServiceAbstract->OMV\Rpc\{closure}('/tmp/bgstatus6i...', '/tmp/bgoutputht...')
#6 /usr/share/php/openmediavault/rpc/serviceabstract.inc(159): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
#7 /usr/share/openmediavault/engined/rpc/config.inc(213): OMV\Rpc\ServiceAbstract->callMethodBg('applyChanges', Array, Array)
#8 [internal function]: OMVRpcServiceConfig->applyChangesBg(Array, Array)
#9 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#10 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('applyChangesBg', Array, Array)
#11 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Config', 'applyChangesBg', Array, Array, 1)
#12 {main}
