QNAP [ Clutch ] [ 0.200727] Extensible platform for infrastructure management
QoolBox
Représentant QNAP
2 Janvier 2014
10 710
183
158
51
www.qnap.com
logoMark.svg
Source : https://github.com/lyft/clutch
Download :
https://www.qnapclub.eu/fr/qpkg/1009
Clutch provides everything you need to simplify operations and in turn improve your developer experience and operational capabilities. It comes with several out-of-the-box features for managing cloud-native infrastructure, but is designed to be org-agnostic and easily taught how to find or interact with whatever you run, wherever you run it.
? Highly extensible.
Extension points exist throughout the stack to allow custom integrations without rewrites.
Clutch is configuration-driven so it can be deployed and reconfigured for varied environments with ease.
Private extensions can be plugged-in without maintaining a fork.
? Built for discovery.
Resources have many common names. Clutch's Resolver pattern makes it easier than ever to locate resources.
The Resolver provides server-generated forms with one-line of frontend code, ensuring the API and frontend are always in sync.
? Easy to develop, run, and maintain.
Developed with Go and Typescript, plus Protobuf for generated interfaces throughout.
Back-end abstractions ensure loose coupling and put feature development on rails.
Frontend components make it simple for developers with limited frontend experience to ship features.
Deployable as a single binary containing both backend and frontend resources.
Basic auditing, authorization, stats, and logging come for free with every endpoint.
? Secure and observable.
Single sign-on support.
Role-based access control (RBAC) engine for granular access control beyond what vendor IAM policies support.
Built-in auditing with sinks for Slack and more.
Extensive logging and stats capabilities.
