OMV6 Clamav ne s'installe pas
Mister-h1664
13 Juin 2022
4
J'ai essayé d'installer clamav sur mon NAS, mais celui-ci me renvoi une erreur 500...pourriez-vous m'aider ? Ci dessous le message :
Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; export DEBIAN_FRONTEND=noninteractive; apt-get --yes --allow-downgrades --allow-change-held-packages --fix-missing --allow-unauthenticated --reinstall install openmediavault-clamav 2>&1' with exit code '100': Reading package lists...
Building dependency tree...
Reading state information...
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
openmediavault-clamav : Depends: clamav-daemon (>= 0.102) but it is not installable
Depends: clamav-freshclam but it is not installable
Depends: clamdscan but it is not installable
E: Unable to correct problems, you have held broken packages.
OMV\ExecException: Failed to execute command 'export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/local/bin:/usr/local/sbin; export LANG=C.UTF-8; export LANGUAGE=; export DEBIAN_FRONTEND=noninteractive; apt-get --yes --allow-downgrades --allow-change-held-packages --fix-missing --allow-unauthenticated --reinstall install openmediavault-clamav 2>&1' with exit code '100': Reading package lists...
E: Unable to correct problems, you have held broken packages. in /usr/share/openmediavault/engined/rpc/pluginmgmt.inc:247
Stack trace:
#0 /usr/share/php/openmediavault/rpc/serviceabstract.inc(588): Engined\Rpc\PluginMgmt->Engined\Rpc\{closure}('/tmp/bgstatuszE...', '/tmp/bgoutputxi...')
#1 /usr/share/openmediavault/engined/rpc/pluginmgmt.inc(251): OMV\Rpc\ServiceAbstract->execBgProc(Object(Closure))
#2 [internal function]: Engined\Rpc\PluginMgmt->install(Array, Array)
#3 /usr/share/php/openmediavault/rpc/serviceabstract.inc(123): call_user_func_array(Array, Array)
#4 /usr/share/php/openmediavault/rpc/rpc.inc(86): OMV\Rpc\ServiceAbstract->callMethod('install', Array, Array)
#5 /usr/sbin/omv-engined(537): OMV\Rpc\Rpc::call('Plugin', 'install', Array, Array, 1)
#6 {main}
