QNAP [ TransmissionBT v3 ] [ 3.0.0.3 ] Transmission is a fast, easy, and free BitTorrent client.
QoolBox
Représentant QNAP
2 Janvier 2014
10 745
185
173
51
www.qnap.com
Oui
Source : https://github.com/transmission/transmission
Download : x86 , x31, x41, arm64, arm-x19, x64
https://www.qnapclub.eu/fr/qpkg/976
QPKG Integration
Config file : /opt/QTransmission3/etc/config/json
default credential : qnap /qnap
C'est quoi la différence avec la version précédente ?
Sent from my ONEPLUS A5000 using Tapatalk
Thank you, it works great!
Is it possible to keep the folder name the same "QTransmission" instead of "QTransmission3"? Maybe this way it can perform an "in-place" update without losing the settings?
Hi again,
I have been testing out v3.0 on my Qnap TS-1677X, and it is acting a little weird.
The installation works flawless (used the repo in Qnap WebGUI), and I edit the settings.json, and that is working, so far so good.
Today after it have been running all night, my system memory was low. I have 16 GB, and 2 GB reserved for a VM server. That have never happened before.
I checked Transmission through Transmission Remote GUI, and saw a couple of trackers had no connection, checked if Transmission v3 was whitelisted on the sites, and only one of them hadn't whitelisted it yet.
I removed Transmission completely from the NAS, rebooted, updated the firmware (manually), installed Transmission v3 (downloaded the file manually), stopped the service, edited settings.json, started the server.
The settings was back to the old settings with qnap / qnap and so on. Tried a few times and finally it went through.
It was still the same with the trackers as before - the same ones didn't work.
Tried a new port number - same result (yes, I have opened it in my router).
Tried to test the port through Transmission Remote GUI, and got and error with no http. Tested it on my other 2 Qnap's, and they responded with everything working (they run Transmission 2.94).
Shut down the Transmission app through App Center in Qnap WebGUI, but noticed that Transmission Remote GUI still had access to Transmission v3 on that NAS, so it's like there is running another instance of Transmission v3 in the background...
I have never experienced this before, and have been using Transmission for years on my Qnap systems...
Thanks for the latest 3.0.0.1 update!
I have to mention that it has overwritten my settings, which are not located as indicated in
but rather in /opt/QTransmission3/etc/settings.json
Also, I am moving my post from the previous version to this thread:
It would be great to add to the release the improved Web Interface found here: https://github.com/ronggang/transmission-web-control
Steps I have followed to install.
  • Stop Transmission, this is important as changes are reverted if Transmission is running.
  • Clone web server tree is found here: https://github.com/ronggang/transmission-web-control/tree/master/src
  • Copy the files from the download src folder to /opt/QTransmission3/share/transmission (in my NAS)
    I have created a folder called remote-control.
  • Edit QTransmission3.sh (/opt/QTransmission3/) and add the line
    export TRANSMISSION_WEB_HOME=$QPKG_ROOT/share/transmission/remote-control
    after
    export HOME=$QPKG_ROOT
  • Restart Transmission and the new interface should be online.
I guess that an upgrade will overwrite the QTransmission3.sh file, which will need to be edited again while maintaining the settings.
Note:
Do not be frightened by the Chinese screen captures, although the readme (https://github.com/ronggang/transmission-web-control) is in chinese, the web interface is actually in English, and it has some other languages as well as French and Spanish (as shown here: https://github.com/ronggang/transmission-web-control/tree/master/src/tr-web-control/i18n)
For the English read me: https://github.com/ronggang/transmission-web-control/wiki
I have not used the install script, rather than that I performed the steps listed in my previous post.
The install script stored here (https://github.com/ronggang/transmission-web-control/blob/master/release/install-tr-control.sh) may perform other activities. You could take a look to understand its inner working. I lack some knowledge to fully understand it.
In my setup:
Thanks again and regards.
Transmission web remote contol is release as another qpkg.... Available on qnapclub
Envoyé de mon MI 9 en utilisant Tapatalk
Hi,
there is an Problem by using SSL Trackers etc. i think it is caused on the reason that transmission is verifying SSL certificates since version 3.0
see
https://github.com/transmission/transmission/pull/334
https://github.com/openwrt/packages/issues/5665
For that check there is an ca bundle file needed that mused be stored in /etc/ssl/certs/ca-certificates.crt
i talk about the Funktion to test if the configured Port for transmission is open or not.
That stops working a few months ago
Salut et merci pour ton expertise sur Transmission,
y' t'il la place sur le serveur dorénavant pour le package en ARM-X19? Mon vieux TS-412 et moi sommes impatients. :D
Bye!
EddyOops a dit:
quelles différences avec Qtransmission?
Transmission est la version officielle du logiciel, maintenue par l'auteur original et sa communauté. Qtransmission est un portage officieux fait par Quolbox. Il est (plus) souvent mis à jour pour les Qnap.
