Synology Problème ou pas sur Watchtower
  • Auteur du sujet Auteur du sujet bret
bret
19 Février 2017
171
32
53
Bonjour ,
j'ai depuis peu ces informations dans mes logs Watchtower , cela vous semble t'il normal ?
Merci pour vos commentaires
Cdlt
Bret
WARN[921237] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[921237] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[921246] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[921246] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[921248] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
WARN[1007596] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1007596] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1007608] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1007608] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1007617] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1007617] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1007627] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1007627] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1007636] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1007636] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1007646] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1007646] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1007647] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
WARN[1093996] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1093996] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1094006] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1094006] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1094015] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1094015] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1094024] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1094024] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1094034] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1094034] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1094043] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1094043] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1094045] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
WARN[1180396] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1180396] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1180408] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1180408] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1180418] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1180418] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1180427] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1180427] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1180436] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1180436] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1180446] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1180446] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1180447] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
WARN[1266796] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1266796] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1266809] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1266809] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1266819] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1266819] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1266828] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1266828] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1266838] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1266838] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1266847] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1266847] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1266848] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
WARN[1353196] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1353196] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1353206] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1353206] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1353215] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1353215] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1353225] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1353225] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1353234] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1353234] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1353243] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1353243] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1353245] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
WARN[1439596] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1439596] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
INFO[1439617] Found new ghcr.io/linuxserver/tautulli:latest image (c6e3d9de95d8)
WARN[1439625] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1439625] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1439634] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1439634] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1439643] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1439643] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1439654] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1439654] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1439663] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1439663] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1439664] Stopping /tautulli (6dfca640ae3e) with SIGTERM
INFO[1439670] Creating /tautulli
INFO[1439672] Removing image 3d9fb1194fb5
INFO[1439674] Session done                                  Failed=0 Scanned=6 Updated=1 notify=no
WARN[1525996] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1525996] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[1526009] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[1526009] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[1526018] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1526018] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[1526027] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1526027] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[1526037] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[1526037] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[1526046] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[1526046] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[1526047] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
Non, je n'ai pas ça dans les logs de Watchtower chez moi. Peut-être qu'il manque la définition du réseau dans le compose.yaml de docker.
j'ai modifié mon fichier compose , on verra bien ! le même fichier ne se comporte pas du tout pareil sur mon autre Syno , c'est vraiement étrange ....
Que veux-tu dire par là et quels sont les modèles de NAS ?
Poste ton fichier de config ici pour qu'on puisse t'aider le cas échéant.
Pour l'instant je pars en vacances , je verrais cela en rentrant !
c'est une bonne remarque ! j'en prends note .
Bonjour;
Me voici de retour , je possède deux syno le premier le A (916+) , le second le B (718+) . Le A avec container manager ( portainer-jellyfin-jellystat-tautulli-watchtower) , c'est celui ci qui pose problème ( voir les logs ci-dessus) .Le B avec container manager (portainer-glueten-qbittorrent-vaultwarden-watchtower) celui ci tout est correct , ci joint mon ficher compose de watchtower , il faut savoir que j'ai essayé d'autre fichier reduit au strict minimun , mais le résultat est le même , si vous avez des idées .....
services:
  watchtower:
    image: containrrr/watchtower:latest
    container_name: WATCHTOWER
    hostname: watchtower
    mem_limit: 512m
    mem_reservation: 128m
    cpu_shares: 512
    security_opt:
      - no-new-privileges=true
    read_only: true
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock:ro
    environment:
      TZ: Europe/Paris
      WATCHTOWER_CLEANUP: true
      WATCHTOWER_REMOVE_VOLUMES: false
      DOCKER_API_VERSION: 1.45
      WATCHTOWER_INCLUDE_RESTARTING: true
      WATCHTOWER_INCLUDE_STOPPED: false
      WATCHTOWER_SCHEDULE: 0 0 19 * *
      WATCHTOWER_LABEL_ENABLE: false
      WATCHTOWER_ROLLING_RESTART: true
      WATCHTOWER_TIMEOUT: 30s
      WATCHTOWER_LOG_FORMAT: pretty
    restart: on-failure:5
Je pense que @MilesTEG saurait te conseiller, j'ai souvenir d'avoir lu qu'il avait eu un problème similaire avec Watchtower, mais je n'ai pas retrouvé l'article.
Salut 👋🏻
J’ai effectivement déjà eu ce genre de problème…
C’est soit un nombre de requêtes dépassés, il faut alors connecter un compte docker.
Sinon c’est un problème de connexion internet.
Regarde si a la prochaine exécution a refait les mêmes erreurs.
Bonjour ,
Je viens de vérifier, c'est toujours d'actualité .....
INFO[0001] Watchtower 1.7.1
INFO[0001] Using no notifications
INFO[0001] Checking all containers (except explicitly disabled with label)
INFO[0001] Scheduling first run: 2025-08-11 02:00:00 +0200 CEST
INFO[0001] Note that the first check will be performed in 15 hours, 46 minutes, 22 seconds
WARN[56791] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[56791] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[56800] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[56800] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[56810] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[56810] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[56819] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[56819] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[56829] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[56829] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[56838] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[56838] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[56839] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
j'ai rajouter la variable , on verra bien !
PS: même résultat , par contre je n'ai pas compris " as tu essayé de connecter un compte docker " ?
je viens seulement d'appliquer ta recommandation, je voudrais être sur d'avoir bien procéder ! alors je me suis connecté en ssh (root) sur mon nas , puis j'ai appliqué ton fichier " docker login -u mon user , il m'a ensuite demandé mon password , puis il indique action réussi ou quelque chose du genre ! malgré cela aucune amélioration ....
PS : je viens de faire une nouvelle réinstallation et cela semble avoir fonctionner , je vais voir sur plusieurs jours ! ..... j'ai oublié de préciser , j'ai coupé le pare feu c'est peut être là le problème
Mauvaise nouvelle ce matin cela ne fonctionne pas , retour à la case départ !
INFO[0001] Scheduling first run: 2025-08-16 10:00:00 +0200 CEST
INFO[0001] Note that the first check will be performed in 37 minutes, 56 seconds
WARN[2285] Could not do a head request for "containrrr/watchtower:latest", falling back to regular pull.  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[2285] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/WATCHTOWER image="containrrr/watchtower:latest"
WARN[2294] Could not do a head request for "ghcr.io/linuxserver/tautulli:latest", falling back to regular pull.  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[2294] Reason: Get "https://ghcr.io/v2/": dial tcp: lookup ghcr.io on 127.0.0.11:53: server misbehaving  container=/tautulli image="ghcr.io/linuxserver/tautulli:latest"
WARN[2305] Could not do a head request for "portainer/portainer-ce:latest", falling back to regular pull.  container=/portainer image="portainer/portainer-ce:latest"
WARN[2305] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/portainer image="portainer/portainer-ce:latest"
WARN[2315] Could not do a head request for "cyfershepard/jellystat:latest", falling back to regular pull.  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[2315] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat image="cyfershepard/jellystat:latest"
WARN[2324] Could not do a head request for "postgres:15.2", falling back to regular pull.  container=/jellystat-db image="postgres:15.2"
WARN[2324] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/jellystat-db image="postgres:15.2"
WARN[2333] Could not do a head request for "jellyfin/jellyfin:latest", falling back to regular pull.  container=/Jellyfin image="jellyfin/jellyfin:latest"
WARN[2333] Reason: Get "https://index.docker.io/v2/": dial tcp: lookup index.docker.io on 127.0.0.11:53: server misbehaving  container=/Jellyfin image="jellyfin/jellyfin:latest"
INFO[2334] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
Alors j'ai ouvert le port DNS (53) dans le pare feu et cela semble fonctionner ...... affaire à suivre
INFO[0001] Scheduling first run: 2025-08-16 11:00:00 +0200 CEST
INFO[0001] Note that the first check will be performed in 50 minutes, 47 seconds
INFO[3054] Session done                                  Failed=0 Scanned=6 Updated=0 notify=no
Tu avais bloqué le port DNS en sorti ??
Il ne faut pas bloquer en sortie, mais en entrée.
je n'avais pas ouvert avant et cela marchait très bien !
    61.8 KB · Affichages: 6
tu fais comment pour la sélection !
