QNAP [ Radarr ] automatically downloading movies
QoolBox
Représentant QNAP
2 Janvier 2014
10 693
182
158
51
www.qnap.com
Source : www.radarr.net
Download : x64, arm64
Apache82 https://www.myqnap.org/product/radarr82/
Apache83 https://www.myqnap.org/product/radarr82/
Apache84 https://www.myqnap.org/product/radarr84/
The project was inspired by other Usenet/BitTorrent movie downloaders such as CouchPotato.
Radarr is currently undergoing rapid development, and pull requests are actively added into the repository.
Features
Current Features
Adding new movies with lots of information, such as trailers, ratings, etc.
Support for major platforms: Windows, Linux, macOS, Raspberry Pi, etc.
Can watch for better quality of the movies you have and do an automatic upgrade. eg. from DVD to Blu-Ray
Automatic failed download handling will try another release if one fails
Manual search so you can pick any release or to see why a release was not downloaded automatically
Full integration with SABnzbd and NZBGet
Automatically searching for releases as well as RSS Sync
Automatically importing downloaded movies
Recognizing Special Editions, Director's Cut, etc.
Identifying releases with hardcoded subs
All indexers supported by Sonarr also supported
New PassThePopcorn Indexer
QBittorrent, Deluge, rTorrent, Transmission and uTorrent download client (Other clients are coming)
New TorrentPotato Indexer
Torznab Indexer now supports Movies (Works well with Jackett)
Scanning PreDB to know when a new release is available
Importing movies from various online sources, such as IMDb Watchlists (A complete list can be found here)
Full integration with Kodi, Plex (notification, library update)
And a beautiful UI
Importing Metadata such as trailers or subtitles
Adding metadata such as posters and information for Kodi and others to use
Advanced customization for profiles, such that Radarr will always download the copy you want
I seems that the last version is 3.0.0.4085
Automatic update is not possible is it ?
I see this error in the app
Branch aphrodite is not a valid Radarr release branch, you will not receive updates
Thank you for your work
Hi, the last update broke the installation.
Could you please update to the new release.
Thank you
Lenny
Hi,
can you update to the current radarr version. The current version breaks when updating on the nightly update channel.
Best regards
Lenny
QoolBox a dit:
hi
3.0.2.4552 seems be latest, cant find the nightly build binaries to download on the github.. if you have a link
Hi, here you go but nightly seems buggy, is there a possibility, that your package works with the nightly though?
https://wiki.servarr.com/Radarr_FAQ#How_do_I_update_Radarr.3F
Best regards
Lennart
Radarr 3.1 is now in master.
Would be great, if you can update.
Best regards
Lenny
updated Stable to 3.1.14954
Changes:
8d17f0b Fixed: Round durationseconds in Kodi metadata (#6204)
f2c9fcd New: Remove completed downloads from disk when removing from SABnzbd
2716bd6 Fixed: Not capturing D-Z0N3 preceded with .- [ #6044 ]
5dabec5 Fixed: Links to Sonarr now uses auth cookie
fc61687 New: Calendar iCal feed includes Digital Release events
19d533b Fixed: Search Missing Movies on Calendar
4ce98d6 New: Detect 'FRA' and 'FRE' as French Language [ #6136 ]
ef9c1bf New: Detect 'castellano' as Spanish Language [ #6152 ]
ac5736c New: Add option to import from any Trakt user's personal list
35abd99 Fixed: Some connection settings being invisibly enabled on creation
cbc14a1 New: Make Rarbg category selection more intuitive [ #6138, #6139 ]
2b17b53 Fixed: Show size on disk when deleting movies
88780f3 New: Health Check for Downloads to Root Folder
1ed3071 Fixed: Perform normal search when id search fails [ #6123 ]
3b3dbfe Fixed: Default Newznab cats and descriptions [ #5965 ]
ea3a617 Fixed: Cleanse Notifiarr APIKey from logs
e9ece8a Fixed: Typos in Naming Modal
22a5304 Fixed: Interactive import modal horizontal scrolling on Firefox mobile
50ebd28 Fixed: Unnecessary idle cpu usage
53b9332 Fixed: Qbittorrent api errors when only one of two seed criteria was configured
bfc969c New: TMDb Lists using V4 api
6267497 Fixed: User TMBd lists paging
efeb216 New: Import List by TMDb Company ID
f3fb67a Fixed: Setting seed criteria while torrent is still being loaded by qbittorrent
ec8d1c4 Fixed post-install update check not running
bef12f1 Fixed: Missing Translates
8064a43 Fixed: Updates to System > More Info
2e0d603 Fixed: Spelling of Separate in Email Notification Settings
e8972f2 Fixed: Don't set cookies for static resources
fc12770 Fixed: Set SameSite=Strict for SonarrAuth cookie
5d5e66f Fixed: Cache headers for static resources [ #4356 ]
59f8a4d Fixed: Remove selected in queue
a3723b5 Fixed: Restoring a backup with a different API didn't reload properly
e9e034d Fixed: Removal of previous service
52dbcfe Fixed: Queue refresh closing manual import from queue if items change
5926ca5 New: On Movie Delete and On Movie File Delete Notifications
8a062d1 Fixed: Remove AwesomeHD [ #5978 ]
4acd885 Fixed: Cleanse Tracker Announce Keys from logs
aa9880b New: Trakt Recommended Lists [ #5980 ]
7ea749e Fixed: TMDB link in discord notifcation from .com to .org [ #5975 ]
a979297 Fixed: Mark as Failed errors (#5939) [ #5907, #5938 ]
a680119 Fixed: Error checking if files should be deleted after import won't leave import in limbo [ #5917 ]
2fd030b New: Health check for import lists with missing root folders [ #5908 ]
33cd9f5 Fixed: Unable to close indexer category select input on mobile
108609d New: .NET 5 support for FreeBSD 11+
0fcad53 Fixed maintenance release not showing as such in AppUpdatedModal
fa6b7ad Fixed: Map 4k H265 releases as 4k
b51ce06 Fixed: Correctly Map 2160p releases that are BRRips as 2160p [ #5639 ]
63cf10c Fixed: Restoring backup from zip file on disk
6b5e743 Fixed: Don't ignore default Boolean in db serialization
d8c962a Fixed: Detect Dolby Vision as HDR [ #5860 ]
6702c7d New: Add Arabic Language [ #5883 ]
47c2a15 Fixed: RemoteUrl overridden for Movie call with TmdbId param
4bf726c Fixed: Table column order resetting after refresh [ #4297 ]
dd61480 Fixed: Settings fields being altered during save [ #5871 ]
901723b New: Log out body for bad API requests
3a146ea Fixed: Adding indexers from presets
8831fd7 Fixed: Grab ImdbId and TmdbId from Rarbg results
35a53c5 New: Store FileId on Import History Events
9b85f32 New: Allow Manual Search when Movie not monitored [ #3235 ]
012fe53 Fixed: Don't Parse TMDb id and IMDb id as group
566c140 New: Handle select groups that do not follow -RlsGrp format [ #3550 ]
83c637e Fixed: Two VideoCodec naming token options [ #5862 ]
621edba New: Faster initial movie load
f03dfda New: Use System.Text.Json for Nancy and SignalR
7742a81 Fixed: Use Tag Label instead of db Id for Kodi Metadata [ #5713 ]
8588d2e Fixed: Validation of new qbittorrent max-ratio action config
86c5f06 Fixed: Awesome HD website link updated (#5832)
6d7fb3d Fixed: Status on search showing queue status instead of missing (#5854)
a0d2af5 Fixed: Naming Token Regex can fail on certain Cultures (#5855)
aa95781 Fixed: RootFolders may not load when adding collections [ #5753 ]
6e46720 Fixed: FLAC audio channels in media info
efdb9c2 Fixed: Removing completed download from SABnzbd [ #4445 ]
e9cf9d0 Fixed: Refresh queue count when navigating Activity: Queue
8ef4429 New: ISO 8601 Date in log files [ #6224 ]
7c5fc1e New: Adds SSL option to Kodi connections (#6219)
c66f7ab Fixed: Parsing RSS with null values (#6220)
ce6f525 Fixed: Incorrectly grabbing revision downgrades (#6194)
Hi @QoolBox!
Thank you for the updates. I would like to update my version to .NET, and am aware that dependencies call for Apache 74 or 80.
Before commiting to purchase the paid version, can you please confirm if it will work fine on a TS-469 Pro running Radarr, Bazarr, Sonarr, Jacket, Unifi and Transmission?
Also what would be the differences to choose either of the two.
Thank you!
BTW: v3.2.0.5048 has been released.
